pprindeville
Jan 21, 2025Guide
RV rooftop antennae for MR6550 nighthawk
Hi, We recently looked into getting an RV and are wondering about combination antenna like the Winegard 360deg which has AM/FM, TV, WiFi, and LTE/5G capability which seems to be very popular, but...
Jan 21, 2025Guru - Experienced User
the only issue you'd run into is the MR6550 only has the lte-5g connections. so unless you're hooking the winegard up to something else, it'd be overkill.
