RobbyR
May 25, 2024Follower
Sending SMS from MR6450 or MR6500.
There is no option to send SMS with the MR6450 or MR6500 !! I never had a mobile router that did not have that option. For the Netherlands you absolutely need that option to request extra GB on a...
PetarB
Jan 08, 2026Aspirant
There are specialized 5G routers devices who allow you not only SMS gateway (but two SIMs) like Cudy p5, then travel convenient: GL.iNet GL-XE300 (Puli) or the newer GL-XE3000 (Puli AX). M3 can't do these things, you got a wrong router. Albeit Netgears have great hardware, software is the problem.
PetarB
Forgot to mention MikroTik router too can have full SMS gateway with ton of adjustments if you need SMS capability.
