JustinSF
Aug 12, 2020Aspirant
Serial Number Search - Netgear Nighthawk M1 Mobile Router
Is the Netgear Nighthawk M1 Mobile Router manufactured with a Serial Number? If so, can someone clearly explain where that is found? I have spent literally two days between the T Mobile SIM card acti...
celler
Aug 12, 2020Guide
I believe you may be the victim of semantics. These types of devices are identified by what is called an IMEI which is a type of elecronic serial number. You will find it on a sticker under the battery. I also believe you can find this on the GUI on the router by signing into it. Good luck.
JustinSF
I will try that - thanks. The serial number input says 13 digits, but I will try the IMEI.
- cellerAug 12, 2020Guide
Well that could be an issue because the IMEI is 15 digits.
- JustinSFAug 12, 2020Aspirant
Thanks. The IMEI on the Mobile Router box is much longer than that : (
So I give up at this point. I will try to figure out how a person contacts actual support within Netgear, but I'm not optimistic that this product works, or will work. Thanks for your help.
Correction, and my error. I found the Serial Number. It is separate and distinct from the EMEI. Next step is to try chat support to see if anyone can figure out why this Router doesn't/cannot move data, even though an activated SIM card is inside of it, and even though I can attach my iPhone to it.
I am going to correct myself and apologize for erroneous information. If you look on the sticker behind the battery under the IMEI number there is a very small, bearly readable serial number listed. Get out your glasses.
No harm no foul. You are very kind. And yes it is unbelievably small print : )
