luninha's avatar
luninha
Setting Up a password with a Space
Hello all,
I have to configure a 2 way radio connecting it to the internet in order to validate license or run some sort of validation. The problem is that the radio comes with a SSID and password pre-configured. So, in order to connect the radio to my Nighwak I need to set up a SSID and Password to match radio pre-configuration. The proble is that the radio password has a space caracter which I am unable to set on my Nighthawk
Is that a way to set a password with a space Caracter on Nighthawk?
Model : Nighthawk M2
Firmware : NTGX24_10.19.03.OO
Thank you
      • plemans's avatar
        Are you trying to change it directly on the M2 or using the browser or the app?
