Markg1999
Dec 18, 2020Initiate
setting up new tv
Can I connect my tv to this with an ethernet cable ?
Dec 18, 2020Guru - Experienced User
Should be able to.
Are you having issues?
If so what issues specifically are you having?
might want to post in the routers section and not the mobile hotspot/router section if its for a router
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
