Markg1999
Dec 18, 2020Initiate
setting up new tv
Can I connect my tv to this with an ethernet cable ?
Dec 18, 2020Guru - Experienced User
Should be able to.
Are you having issues?
If so what issues specifically are you having?
Markg1999
Dec 19, 2020Initiate
I'm not havung problems, was just wondering. gettting the tv delivered next week..
Thanks
- michaelkenwardDec 20, 2020Guru - Experienced User
What's the TV? Does it support Ethernet? Wifi?
