arosicka
Mar 30, 2017Follower
Setup Nighthawk M1 as 4G router with thrid party Wireless APN
Hi,
I am relocating one office to another.
The existing office has ADSL, and we have a standalone WiFi APN connected to the ADSL router.
We have purchased a Nighthawk M1 as the new office does not have ADSL, only choice is to use 4G connection.
Can I setup the M1 to disable the WiFi, or at least enable the existing WiFi APN to use the M1 as the gateway/router.
Help would be appreciated.
1 Reply
- EveryoneAspirant
Yes, you can disable the WiFi. If the firmware doesn't allow it, then I'll tell you how to do it using Qualcomm's proprietary software, QXDM Professional.
By the way, if I send you $300 PayPal, will you ship me a Telstra M1? I live in the U.S. and it isn't available here, from what I can tell.
