Jim1648
Apr 21, 2023Initiate
Should I Go With A MR5200 or MR6150?
I use both AT&T and T-Mobile data lines. I want a hotspot that will do 5G with either AT&T or T-Mobile. It looks like the Netgear MR5200 or MR6150 might be good choices. What are the diff...
Apr 21, 2023Guru - Experienced User
If they're roughly the same price for you, go with the MR6150. Faster 5ghz speeds and a newer chipset.
There's a pretty solid review of the M5 vs M6 on dongknows.
https://dongknows.com/netgear-nighthawk-m6-mobile-router/
