myinter5
Feb 13, 2021Aspirant
Sim Card for LB1120 Modem
How do ask my ISP to setup the sim card? should I tell them the Data will be used on my cellphone or the modem/router?
myinter5 wrote:How do ask my ISP to setup the sim card?
Depends widely on your mobile provider and its offerings. You might need a dedicated contract (primary for data, no bundled voice calls for example) coming with a dedicated SIM, or your provider offers multi-SIM cards on the same mobile account and number.
myinter5 wrote:should I tell them the Data will be used on my cellphone or the modem/router?
Not sure this is an option at all.
- myinter5Aspirant
Thanks Shumaku, I now know how to go about it.
