JoelSch
Nov 11, 2021Follower
Sim not recognized
I just got my Nighthawk mr1100, I’m trying to use a Verizon sim from another hot spot but it says sim not installed. I re-installed it couple times turned the machine on and off even tried to reset b...
JohnPeng
Nov 12, 2021NETGEAR Expert
Please check whether the PINs of SIM connector are not deformed. You can carefully raise them if they got flattened during to previous uses.
Thanks
