KeithW52
May 05, 2022Aspirant
SIM PIN locked on MR1000
I am changing the sim in my mr1000 and it says that the pin is locked. However the sim works perfectly well in my phone - what to do please?
KeithW52
May 13, 2022Aspirant
Hi Blanca_0
Thank you for your reply. I've tried this many times following the instructions bur I do not know the admin password or the sim pin where can I find these please
Kind regards
Keith
JohnPeng
May 15, 2022NETGEAR Expert
Please do a factory reset. Then you can use the admin password printed on the product label to log in to the WebUI.
For the SIM PIN, if you don't enable it, you can ask your carrier for the SIM PIN set for your SIM card.
Thanks
