asalmuhanna's avatar
Apr 11, 2022
SKU: MR5100-1Z1MES Update
Dears , i would like to ask about problem with OTA update on m5 mobile Routers SKU: MR5100-1Z1MES. There three OTA update for the router :   10.12.13.0   10.28.02.00   12.04.12.01   some rou...
  • Blanca_O's avatar
    Blanca_O
    Apr 13, 2022
    Hi, All,
    I got an update from the product team. There are two different FWs for MR5100-1Z1MES units. The FW v10.x.x.x is the latest FW for MR5100 units with 4GB of memory. And the customer with 8GB of memory MR5100 can only update to FW v12.04.12.01.
    As for the issues with the FW 10.x.x.x, kindly report those issues to Zain for them to check.
    Blanca
    Community Team
