asalmuhanna
Apr 11, 2022Guide
SKU: MR5100-1Z1MES Update
Dears , i would like to ask about problem with OTA update on m5 mobile Routers SKU: MR5100-1Z1MES. There three OTA update for the router : 10.12.13.0 10.28.02.00 12.04.12.01 some rou...
- Apr 13, 2022
Hi, All,
I got an update from the product team. There are two different FWs for MR5100-1Z1MES units. The FW v10.x.x.x is the latest FW for MR5100 units with 4GB of memory. And the customer with 8GB of memory MR5100 can only update to FW v12.04.12.01.
As for the issues with the FW 10.x.x.x, kindly report those issues to Zain for them to check.
Blanca
Community Team
Blanca_O
Apr 12, 2022NETGEAR Employee Retired
Hi, All,
Welcome to NETGEAR Community!
Let me check on this. We will provide update once new information will be available.
Can you also describe the issue you are facing with the current firmware?
Blanca
Community Team
- asalmuhannaApr 13, 2022Guidejust need to update to the last version , it's stable version.
- Blanca_OApr 13, 2022NETGEAR Employee Retired
Hi, All,
Blanca
Community Team
