gregs1
Apr 24, 2018Aspirant
Slow internet speeds both wired and wireless on C7000v2
My C7000 WiFi speeds are about half of what the modem produces when turn the router mode off and hardwire the C7000 to a external router, wifi performance is good. Spectrum tecs tested the C7000's m...
JasonN
Apr 25, 2018NETGEAR Employee Retired
Hi gregs1,
Thank you for coming to the community for help. Is your C7000's firmware up-to-date with the most current version? Did you perform a factory reset on your device? I see that you also listed the Nighthawk AC1900. Where does that device come into play?
Please let me know. :]
- Jason N
gregs1
May 02, 2018Aspirant
I responded to Jason with more clarification on my problem but no one has given any help in understanding why the internal router's wifi speed is slow (about half ) compared to the senario of using the C7000v2 to feed an external router. I can see no settings in the C7000v2 that would cause this. So need advice on how to fix it. Resetting the unit does not help.
- JasonNMay 11, 2018NETGEAR Employee Retired
Hi gregs1,
I have forward your information that you gave me to my internal team. They will work with you as soon as possible. :]
- Jason N
