mishref's avatar
mishref
Tutor
Apr 17, 2020
Slow internet with ip passthrough mode on MR5200 (M5 - 5G device)
I am testing a IP Passthrough mode on the Netgear M5. It limits the speed of the connection to ~200Mbps when enabled. When I revert to normal (router) mode and double-nat,  the connection speed is 500-800Mbps.
Tests were run over ethernet and the router was factory reset before each test. Is this a device limitation or firmware issue?
Device: Nighthawk M5 (MR5200)
Firmware: NTGX55_10.12.05.00
PRI: 02.04
  • Strange behavior can you verify if the slower Throughput rate from the MR5 end or the router connected to it.
    • mishref's avatar
      mishref
      Tutor
      Both - I connected it directly to the ethernet port (of two different devices) for testing.
      And after the last firmware update, passthrough mode stopped working altogether.
      • Dalilama's avatar
        Dalilama
        Initiate
        Extremely disappointing, they killed the option rather than fixing it. Had high hopes for this 5G router.
        Any feedback from support?
    • nmperera's avatar
      nmperera
      Initiate
      Although this is a 5g cellular, the router is only 1g. So the input can be 5g, but the output is 1g. Unfortunately this model does not have a 10g lan or sfp+port, so you are limited to getting less than 1g speeds unless you can use wifi. I think, netgear missed the point of having the 5g cellular with 1g ethernet that limit some users who rely on wired connections.
      Cheers,
      Madura
      • mishref's avatar
        mishref
        Tutor
        Ethernet connection is fine, I have gotten stable speeds of 800-900mbps over it (which is amazing for 5G). My issue is that passthrough mode (disabling the double-nat) was slow. In the latest update it doesn't work altogether.
