mishref
Apr 17, 2020Tutor
Slow internet with ip passthrough mode on MR5200 (M5 - 5G device)
I am testing a IP Passthrough mode on the Netgear M5. It limits the speed of the connection to ~200Mbps when enabled. When I revert to normal (router) mode and double-nat, the connection speed is 50...
alanplum
Dec 12, 2020Aspirant
I can also confirm however that in IP Passthrough mode, WAN speed appears to be throttled to ~200Mbps as per the original post.
When in router mode with double Nat, I'm getting 300-400Mbps
jangal
May 22, 2021Aspirant
I know this is old, but came here to add to the speed throttling concerns on IP Passthrough. It's stuck at 150-200mbps no matter what I do.
Simply removing IP passthrough increases the speed up to 600mbps. All the diagnostics like cell ID and channel number are exactly the same.
What gives?
