cmanthey
May 04, 2022Follower
Slow speed on Nighthawk M1 MR1100-100NAS
I have a mobile phone contract that includes a second sim card which can be used for data. So I use the same contract for my phone as for the nighthawk router. When I started using the nighthawk rout...
May 04, 2022Guru - Experienced User
Did you check with your mobile provider?
Some plans limit your speed after a certain data usage thresh hold has been reached for their hot spot plans.
