jjgood
Oct 16, 2020Follower
sma to TS9 connector
Hi,
I am trying to find a SMA to TS9 connector that fits my nighthawk hotspot. I am trying to connect an external antennna. I bought a pair of connectors but they continually fall out of the nighthawk. I have a netgear window antenna and it connects beautifully (clicks right in) into the nighthawk. Can anyone tell where I can find SMA to TS9 connector that fits properly?
Thanks,
Laura
- Blanca_ONETGEAR Employee Retired
Hi jjgood
Welcome to NETGEAR Community!
These links may help you out:
External Antennas for AirCard products
Blanca
Community Team - ReneMR1100Aspirant
Hi, I am dealing with this same issue. Hope you've found one by now. Have returned Proxicast that said it would fit. Going to try this one: https://www.amazon.com/External-Antenna-Hotspots(AT-Nighthawk-Velocity/dp/B07PJC1B1F/ref=cm_cr_arp_d_pl_foot_top?ie=UTF8
all the best,
Rene
