W27
May 06, 2021Aspirant
speed drop
Hi
I am getting 100mb speed from my modem to th eORBI RBK23 router. My speed output from the ORBI drops to sub 20mb daily. After a factory reset th espeed reverts but then drops after a couple of hours. Any sugestions
What modem do you have?
What firmware is on the router?
Do speeds drop if you're hardwired into the orbi?
Are you testing over 2.4ghz or 5ghz? (2.4hz is much slower)
- W27Aspirant
Don’t know th make of Modem as its supplied as part of a Ubiquiti P2P network.Th owners of this have been on site and speed output is consistently 100MBS. Th speed has been checked at the PoE. Linking laptop to PoE I get 100MBS.
When I ethernet pc to ORBI router the speed is the same as wifi.When the wifi speed drops the thernet speed also dropsFirmware is version V2..6.2.104 on router and satellites- plemansGuru - Experienced User
It makes it more challenging when you don't know the network specs you're connected to.
Then we're only guessing.
theer could be concern with a double nat.
