kathon526
Jul 12, 2021Follower
Speed on LB1120 Modem
Have LB1120 with Verizon Sim Card. Getting constant 4-5 green bar constant with external antenna. Also have GL-iNet Travel Router, Model GL-ar750s-EXT. The router shows both connections which I can connect too.
The issue is the speed. I have 0.5-0.8 Mbs download and about 0.6 upload when any router is connected to this modem.
I have two other routers which I have gotten great speeds (30-50 MPS) and replaced on this same LB1120 modem when all three went down to the same slow speed of about 0.5 MPS. So that tells me it is not the router - I would assume.
I'm not a Tech guy so please explain in detail if you know of a fix or where I might be able to go to get to decent speeds.
Thanks for your support,
No RepliesBe the first to reply
