antenaman
Jul 22, 2017Follower
SPH200D Server connection failed
I cannot login to my account on my Cordless Internet Phone netgear SPH200D. It says "Server connection failed". Until yestarday it was working perfecly. I have the latest firmware 1.0.4.80 installed...
tlnet
Jul 22, 2017Initiate
I am experiencing the exact same problem. The server connection for skype login fails. On the handset it says "Server connect failed." On the administrative web interface it says "Server connection failed." There is nothing wrong with the skype account, login confirmed on other devices. Also confirmed that this problem occurs regardless of what router or port the SPH200D is connected to, tried several different routers where other devices connect fine. Also, the SPH200D's network stack appears fine -- it works whether with static IP or with DHCP; connectivity is confirmed by being able to reach the admin web interface.
