chgonzales
Sep 24, 2020Follower
SSH remotely into MR1100
Hello, I just got the MR1100. I would like to SSH remotely to the router (throught AT&T mobile) and access devices connected to it. I have an AT&T provided static IP address and know I need to ...
icaruspony
Sep 27, 2020Luminary
I'm assuming, too, that you are attaching another wifi router to the MR1100 so that you can set up NAT (to share your one IP address with multiple devices) and handle port forwarding and/or UPnP to multiple devices on your network. Those settings would be set up in your secondary router, since the MR1100 can only DMZ (open all ports) pointed to one device, which wouldn't work for multiple servers.
