tiffanieee56
Feb 23, 2023Aspirant
SSID Nighthawk M6 model MR6110
Hi...when you hide your SSID how would I now get to it to sign in and use it? Do you go to where it says "other networks" and put it in manually? Also these forums are very new to me so if I mess u...
schumaku
Feb 23, 2023Guru - Experienced User
yes. Type the network name manually, as it is made hidden and can't be selected therefore. Curious: What was the ide behind hiding the SSID? It's cumbersome for connecting new devices, and it does not add any security.
- tiffanieee56Feb 23, 2023Aspirant
I think my neighbor hacks me ...but I can never find her...is there one simple answer to secure my network...she is a cheap scrounging thief and she is better at this than me apparently...I cant take it anymore...the other thing is is there a business that I could hire to educate me on all this stuff?
- plemansFeb 23, 2023Guru - Experienced User
You don't need to hide your ssid. In fact, the peop;le who are going to be the ones getting on it, can find it easily enough. You just need a good ssid password that she can't guess using wpa2/wpa3 (if the mr6110 has wpa3)
