hexor
Jan 16, 2020Aspirant
Streaming issues with Nighthawk M1
I mainly use this hotspot in the car for streaming i-radio. Unfortunately the link to the mobile network gets lost quite often for a short time and therefore the sound interrupts, not quite enjoyable...
- Jan 25, 2020
Anyway, testing it further the past days, it somehow seems to be solved. Now it just works fine. I have no clue why that is. A possibility could be that the SIM card somehow must have been "activated" through a mobile phone...? Since I had it in the phone and then switched back to the nighthawk it now runs just fine. I hope it stays this way :-)
Thanks for any help.
Bye.
JohnPeng
Jan 19, 2020NETGEAR Expert
Please advise the device SKU and which carrier you are using.
When you run a speed test, what is the spead you can get?
Thanks
- hexorJan 20, 2020Aspirant
Hi John
Thanks for getting in touch.
SKU is MR1100-100EUS.
Carrier is sunrise.
Download speed: ca. 20 MBit/s
Upload speed: ca. 18 MBit/sRTT: ca. 40 ms
speedtest server is hsi.hsr.ch
These values are in line with the mobile phone that I used as hotspot "reference" (where the music runs smooth).
Thanks, Mike
- hexorJan 25, 2020Aspirant
Bye.
- ezenilJan 29, 2020Aspirant
Hi,
What did you do exactly to fix this issue? I am experiencing the same. "Activated" the SIM card on an iPhone 7 and hat speed test results of Down: 20 Mbps and Up: 10 Mbps. Inserted the SIM into the Nighthawk M1 and the speed test (iPhone connected to M1 WiFi) ist download of 0.3 Mbps, not even Whatsapp runs. I have tried turning on and off the M1 but nothing.
I would appreciate the help.
Erick
