cyfarian
Oct 13, 2021Follower
Sudden continual rebooting nighthawk MR1100
I have had my nighthawk for several years. Possibly related, a couple of years ago the battery failed so I've only used It while plugged in since then.
It was working fine until yesterday, it started continuously rebooting. Sometimes it would complete the reboot and stay on for perhaps a minute. Other times, It will cycle through the neck gear logo, and then the AT&t logo, and then reboot on an endless cycle.
I'm not using the original power cable, but I have been using the same USB-C cable for about 5 months without issue.
I have tried several other USB cables, and the issue is happening with all of them.
The SKU number is 6112B. The carrier is AT&t. It will not stay on long enough for me to access the admin control panel.
1 Reply
- JohnPengNETGEAR Expert
Can you try tethering the device using USB cable to your computre without battery and see whether the device can be booted up this way and access WebUI?Thanks
