zhanex3
Apr 16, 2015Novice
Suggestion: Stealth mode
Could you add a stealth mode to the AirCard 781S so it disables the the flashing led... It's very distracting sometimes, especially at night if I leave the modem on as I have it connected to a router.
- DannyJillardNoviceMaybe a bandaid would be your quickest fix?
- apac_seApprenticeHi ZhaneX3,
I don't have an AC781S here with me to test but on the AC782S you can click on Settings - Display - LED - OFF to disable the LED. Try this and see if the option is available to you.
Kind Regards,
Arodi - dineshnaiduAspirantEven i am getting same problem .
- FairytailVirtuosoIf it is not available. You can ask AT&T if it is from them for feature request since they usually provide the firmware.
