AnunC8
May 13, 2019Aspirant
Super Slow Mr1100 Nighthawk
So, I'm really struggling with my ATandT MR1100. The last one they sent me broke, and this new one doesn't seem to be much better. It picks up about one bar, but I've since installed an antenna which ...
- May 20, 2019
Hi AnunC8
Please check the signal quality using the Diagnostics screen found under Settings > Nighthawk M1 Status > Diagnostics section using values below as reference:
RSRP – The average power received from a single Reference signal, and Its typical range is around -44dbm (good) to -140dbm(bad).
RSRQ – Indicates quality of the received signal, and its range is typically -19.5dB(bad) to -3dB (good).
If signal quality is bad then I suggest that you call AT&T to test the signal.
Blanca
Community Team
Blanca_O
May 20, 2019NETGEAR Employee Retired
Hi AnunC8
Blanca
Community Team
- AnunC8Jun 02, 2019AspirantThanks for the thought. Doesn't look good.
My RSRQ is currently -17
My RSRP is currently -106
I don't understand it. I bought an antenna with expensive, good quality cable and mounted on the roof to improve the signal. My tower is only a couple of miles away...
Is there anything I can do on my end?
