AnunC8's avatar
AnunC8
Super Slow Mr1100 Nighthawk
So, I'm really struggling with my ATandT MR1100. The last one they sent me broke, and this new one doesn't seem to be much better. It picks up about one bar, but I've since installed an antenna which ...
  • Blanca_O's avatar
    May 20, 2019
    Hi AnunC8
    Please check the signal quality using the Diagnostics screen found under Settings > Nighthawk M1 Status > Diagnostics section using values below as reference:
    RSRP – The average power received from a single Reference signal, and Its typical range is around -44dbm (good) to -140dbm(bad).
    RSRQ – Indicates quality of the received signal, and its range is typically -19.5dB(bad) to -3dB (good).
    If signal quality is bad then I suggest that you call AT&T to test the signal.
    Blanca
    Community Team
