Retired_Member
Mar 04, 2020Support for M2
Hello everyone, We have a number of these devices in our environment spread across the state, but have no capability to manage and or update them centrally. While they are more of a consumer dev...
schumaku
Mar 04, 2020Guru - Experienced User
Blanca_O please (also move to Mobile Routers, Hotspots & Modems section, thank you!).
- Retired_MemberMar 10, 2020
So know this has moved out of the insight forum, which is what the question was about, does anyone from Netgear have a comment?
- schumakuMar 10, 2020Guru - Experienced UserInsight is a SMB BU product, while the hotspots/MiFi routers/modems are consumer devices. I've requested moving it away because there is neither support for these devices in Insight not are there any plans to integrate as far as I know as a non-Netgear person.
A feature request for a mobile management platform does belongs to a different BU. Insight or any other implementation might be the possible platform. On my opinion, there might be not enough feature and capability overlap - similar for example Orbi Pro where adding it into Insight opened up discussions on feature gaps of the device side.- Retired_MemberMar 10, 2020
Thanks,
So there is no method to understand the roadmap going forward or to request support for the device with insight?
While I understand the M2 is consumer, there is no SMB or enterprise solution avalilable that performs this role for a mobile.
Cheers
John
