Albo3li
Aug 29, 2018Guide
Supported bands on the MR1100-1RDMES model?
Hello, i have tried to search everywhere about the Nighthawk M1 MR1100-1RDMES model and what bands does this model use or what LTE Carrier Aggregation does it support but i can't find anything!
- Nov 22, 2018
Albo3li MR1100-1RDMES supports the following bands:
4G LTE Bands: 1, 3, 7, 8, 20, 28, 38, 40 and 41
3G WCDMA Bands: 1, 2, 5, and 8
As far as CA combos go it support the bands that Ooreedoo Kuwait would have requested from Netgear.
schumaku
Aug 30, 2018Guru - Experienced User
MR1100-1RDMES is a carrier specific model made for Ooredoo -> Product Datasheet (MR1100-1RDQAS) for Ooredoo
All MR1100 variants offer 4G LTE Advanced Category 16 with 4X4 MIMO, 4-band Carrier Aggregation and LAA.
As it's a branded device, be aware a SIM lock might be in place.
- Albo3liAug 30, 2018Guide
The one you showed is another model MR1100-1RDQAS and every model support different bands and CA + in my country they use 800 band and the model you showed doesn't support it..
There is alot of models (MR1100-1TLAUS/MR1100-100EUS/MR1100-100NAS) and others so i need to know what model bands does MR1100-1RDMES uses
