Passo53
Nov 25, 2018Initiate
Supported LTE frequency ranges
Hi,
I do have MR1100-100EUS (Nighthawk M1) here in Finland. The network I'm trying to connect is called Yhteisverkko (by two operators DNA and Telia together).The general frequency is 800 Mhz.DNA h...
- Nov 26, 2018
Hi,
You have a misunderstanding what comes to those 800 Mhz frequencies. Yhteisverkko(Finnish Shared Network) uses combined spectrum for 800 MHz bandwidth 20 MHz(Telia 10 MHz+DNA 10 MHz). When it is combined there is no carrier aggregation, it is a single cell thing.. Carrier aggregation called B20+B20 does not exist. When you see that 4G+ RAT symbol sometimes it probably means that your MR1100 device and basestation try to use carrier aggregation between B20 and some other frequency band.
TeeJay74
Nov 26, 2018Virtuoso
Hi,
