sharpstick
Feb 27, 2023Guide
T-Mobile gateway alternative - Nighthawk M6?
I have T-Mobile home internet and have had problems using their Nokia 5G21 gateway. I'd like to try a Nighthawk M6. What submodels will work(regular and Pro?). It looks like the MR6500 is ATT only. T...
Feb 27, 2023Guru - Experienced User
got an old router sitting around?
Couple reports of the built in router having issues. MIght connect an old router to the gateway and see if it stays stable/fast.
- sharpstickFeb 27, 2023Guide
I would think that would help the downstream gateway to device connections rather than the tower to GW connections.
