sharpstick
Feb 27, 2023Guide
T-Mobile gateway alternative - Nighthawk M6?
I have T-Mobile home internet and have had problems using their Nokia 5G21 gateway. I'd like to try a Nighthawk M6. What submodels will work(regular and Pro?). It looks like the MR6500 is ATT only. T...
sharpstick
Feb 27, 2023Guide
I also see that the M5, MR5200 should work. My typical speeds are from 50 to 600 mbps. 100 is usually acceptable. The M6 is faster, but with my speeds, will it matter? (M5 is cheaper, too.)
sharpstick
Feb 27, 2023Guide
Netgear chatbot says: "Both can support 5G.
However the MR6150 data transfer speed over wifi is faster than the MR5200." So how much faster, and at 5G 100 - 400 mbps, would that matter?
