Gbear1984
Jul 04, 2023Tutor
Telstra M6 Pro cannot connect to firmware server
Hi, anyone is getting this error when trying to reach Telstra M6 Pro firmware server, to try to get an update? this is my first time seeing this and its been like this for almost 2 weeks. I be...
JohnPeng
Jul 04, 2023NETGEAR Expert
Gbear1984 wrote:
Hi,
I believe Telstra suppose to come up with a updated firmware which will activate the 5G SA capability according to JohnPeng
but there is nothing at all. my device is pretty useless and not able to fully utilise to its fullest. quite disappointed
Telstra maintenance release is in final approval of RCM. Plan to release it some time next week if everything goes well.
Yes. SA will be enabled in the new release.
Thanks
John
- itsonlymarcoJul 13, 2023Aspirant
Same issue, my M6 Pro is stuck with a very old firmware from a year ago. Problem is I do not live in AU and I have made a huge mistake buying it outright from there.
Any news about the firmware release and will it download from the UK with a sim from vodafone?
thanks
- JohnPengJul 14, 2023NETGEAR Expert
thanks
Telstra is going to issue technical approval for the maintenance release next week. I will let you know when the release is posted online for upgrade.
Thanks
- Gbear1984Jul 20, 2023Tutor
Hi John Peng,
Managed to download the new firmware!
however, still not able to get any 5G connections with the new firmware.
Should restore again or something I might not have done correctly?
Thank you!
