Gbear1984
Jul 04, 2023Tutor
Telstra M6 Pro cannot connect to firmware server
Hi, anyone is getting this error when trying to reach Telstra M6 Pro firmware server, to try to get an update? this is my first time seeing this and its been like this for almost 2 weeks. I be...
itsonlymarco
Jul 13, 2023Aspirant
Same issue, my M6 Pro is stuck with a very old firmware from a year ago. Problem is I do not live in AU and I have made a huge mistake buying it outright from there.
Any news about the firmware release and will it download from the UK with a sim from vodafone?
thanks
JohnPeng
Jul 14, 2023NETGEAR Expert
thanks
Telstra is going to issue technical approval for the maintenance release next week. I will let you know when the release is posted online for upgrade.
Thanks
- Gbear1984Jul 20, 2023Tutor
Hi John Peng,
Managed to download the new firmware!
however, still not able to get any 5G connections with the new firmware.
Should restore again or something I might not have done correctly?
Thank you!
- itsonlymarcoJan 03, 2024Aspirant
After receiving the firmware update OTA, the wi-fi dual band is acting up, and it can no longer broadcast dual band.
It is either 2.4 or 5/6 GHz
I have spent 10 hours trying every single configuration and keep restoring to default, but every time I click on the dual-band button, it simply adds "2.4GHz" to the SID and kills the 5G or 6G band, that comes back only if I go back to 5G or 6G only.
I tried 100 of different variations, with/without offlloading, with/without usb, guest network,and every thing else available on webUI app and directly on the touch screen.
This thing costed me a fortune and I can't get it to have the most simple dual band setup!
