homemodem
Dec 08, 2019Tutor
Telstra MR1100 Nighthawk Data Usage Problems.
Hi All, I know this topic has been raised before, but I cannot find an open discussion. I have a Telstra MR1100/M1 modem, and since upgrading the firmware to NTG 9X50C_12.06.02.00, the display only...
- Jan 23, 2020
I have to say Thank You to all your guys for your patience to wait for us to resolve the issue with Telstra.
Regards
JohnPeng
Dec 09, 2019NETGEAR Expert
Telstra made some changes on their data usage server and broke the data usage display on M1. We are testing a fix for this issue and will have it addressd soon in the next couple of weeks. Thanks for your patient.
- homemodemDec 09, 2019Tutor
Thanks for responding.
I look forward to a solution.
Again, many thanks.
- Goldy_13Dec 19, 2019GuideWill this solve the detecting service issue?
- mdgmDec 20, 2019Virtuoso
The "detecting service" error is where they are trying to detect the service to show the usage.
My system wasn't updating the usage so I factory reset it in the hopes of fixing it and now have the "detecting service" error.- Goldy_13Dec 20, 2019GuideThat’s exactly what I did and have the same issue. I was hoping the netgear techies could shed some light
- homemodemJan 15, 2020Tutor
Hi John P, Any news, it's now 16th January 2020!
Still the same problem!!
Regards
- JohnPengJan 16, 2020NETGEAR Expert
Telstra is testing our new release. I expected the fix will be pushed out by us in the next one or two weeks. Please standby.
Thanks for your patience.
- Rob957Jan 16, 2020Aspirant
This data issue is why I have been attempting to get into the app.
But I can't find how to change the device password I set and forgot
I seem to be able to change every other Netgear password except this one
One support link states that there is a server error which is being fixed???
If you want to pay for support they advise that a one time option is available, but when you go to the selection area that option is not shown, leaving only the more expensive comprehensive options. to choose from.
My device still works fine but because this issue, can't know if data allowances are exceeded.
