homemodem
Dec 08, 2019Tutor
Telstra MR1100 Nighthawk Data Usage Problems.
Hi All, I know this topic has been raised before, but I cannot find an open discussion. I have a Telstra MR1100/M1 modem, and since upgrading the firmware to NTG 9X50C_12.06.02.00, the display only...
- Jan 23, 2020
I have to say Thank You to all your guys for your patience to wait for us to resolve the issue with Telstra.
Regards
Goldy_13
Jan 23, 2020Guide
For individuals that are having problems updating the software, I take it that you are trying to update through the dashboard? I had No problems with the download for the installation process through the netgear Mobile app. try this, if you don't have any success on the dashboard. once the firmware has been updated do a reset on the unit see if that fixes the issue.
