homemodem
Dec 08, 2019Tutor
Telstra MR1100 Nighthawk Data Usage Problems.
Hi All, I know this topic has been raised before, but I cannot find an open discussion. I have a Telstra MR1100/M1 modem, and since upgrading the firmware to NTG 9X50C_12.06.02.00, the display only...
- Jan 23, 2020
I have to say Thank You to all your guys for your patience to wait for us to resolve the issue with Telstra.
Regards
billc69
Jan 28, 2020Aspirant
I have the common Telstra problem of the 'Detecting Service' and am trying to upgrade the firmware but it's coming up with an error everytime I try the download.
My firmware version is the correct one but the PRI is 5.03.
How do I upgrade the PRI?
Thumpabar
Jan 29, 2020Aspirant
Hi,
I have the exact same issue, have "Detecting service" and trying to update FW (as it says there is one) but it keeps failing, tried from dashboard, phone app, even another SIM, always fails before starting any download.
Is there a link to a manual FW download?
I have PRI 04.04 and FW 12.06.02.00
Cheers,
Jeff
- Niko_SJan 29, 2020Aspirant
I uodated following the prompts on the unit itself. It worked fine first time.
- JohnPengJan 29, 2020NETGEAR Expert
Please make sure you have enough data on your plan for the download to be happen.
If it is not the case, please do a factory reset and try again.
Thanks
- billc69Jan 29, 2020Aspirant
Thanks for your reply John!
My plan is a shared data plan which has 60gb but this sim card will only show 100mb on the screen (if it was working) as Telstra don't show the overall group data availability on a shared plan.
Would this stop the download and update?
Is it possible to get a link to the file and update manually? Or is there something else that might be wrong?
Bill
- ThumpabarJan 29, 2020Aspirant
Hi John,
I'm on a post paid corporate plan with pooled data after I use my initial 4GB. According to Mobile Data Usage Meter website I still have 3.8GB free!
I've tried factory resetting before doing the previous post. I've also tried updating from the device itself, but it just triggers the same update error on the phone.
How can I download the FW manually and update locally?
Cheers,
Jeff
Hi again John,
I have used the main SIM card (which has 60gb worth of data) and that didn't work.
I have done 3 x factory resets and they haven't made a difference either.
I have tried the update on the device and through the dashboard and that hasn't worked either.
Any other suggestions?
Bill
I was just notified that our FOTA server is under maintenance. It should be back up online soon.
Sorry for the inconvenience. I will let you know when it is ready.
Thanks
