homemodem
Dec 08, 2019Tutor
Telstra MR1100 Nighthawk Data Usage Problems.
Hi All, I know this topic has been raised before, but I cannot find an open discussion. I have a Telstra MR1100/M1 modem, and since upgrading the firmware to NTG 9X50C_12.06.02.00, the display only...
- Jan 23, 2020
I have to say Thank You to all your guys for your patience to wait for us to resolve the issue with Telstra.
Regards
Thumpabar
Jan 29, 2020Aspirant
Hi,
I have the exact same issue, have "Detecting service" and trying to update FW (as it says there is one) but it keeps failing, tried from dashboard, phone app, even another SIM, always fails before starting any download.
Is there a link to a manual FW download?
I have PRI 04.04 and FW 12.06.02.00
Cheers,
Jeff
Niko_S
I uodated following the prompts on the unit itself. It worked fine first time.
