Gbear1984
Feb 23, 2023Tutor
Telstra Netgear M6 Pro not connecting to N78
Hi need some advise on what I can do or approach this matter. I have purchased 2 M6 Pro from Telstra and occasionally I will will travel between Singapore and Australia. However when I put in Singa...
Gbear1984
Feb 23, 2023Tutor
Hi John,
Thanks for that piece of informations. Yes currently Singtel only operates on SA 5G. probably that's why. appreciated that
Any idea how long or when they will release or unlock that feature? understand it is catered for Telstra, but Telstra user who are travelling with the device isn't helping them.
Thank you!
Gbear1984
Mar 15, 2023Tutor
Hi John,
I saw from another trend talking about M6 Unlock version is in development. Can I check that if the firmware can be applied to my current one or I have to buy a unlock version when Netgear release?
Also current, it seem like to check and update the firmware, it requires Telstra network to do so. cannot be done over Wifi.
Able to advise?
Thank you
