dapatter
Oct 19, 2019Aspirant
Telstra Nighthawk M1 Modem and Ethernet port stops working
have been using this as my primary internet router for about 6 months or more. Just moved house, but using the same setup and now the ethernet port seems to shut down quite quickly and only re-enable...
michaelkenward
Oct 20, 2019Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
