DannyLin
Dec 08, 2019Apprentice
Telstra Wi-Fi 4G Advanced III firmware(AC810S) update
Hi, I have a Telstra Wi-Fi 4G Advanced III that I bought from China. I believe it is unlocked. My existing device firmware version NTG9X40C_10.13.02.00. Firware buid date on 2015/09/03....
JohnPeng
Dec 09, 2019NETGEAR Expert
If you can get the data connection on the device, it should be able to pick up the latest update over the air.
You can mannually do a FW upgrade check on WebUI or LCD touch UIto start the upgrade.
Please let me know if you still have any issues.
