Edward_75
Dec 22, 2024Aspirant
Tether mr1100 to phone for cellular data
I just bought a nighthawk M1 gigabit LTE Mobile router. I have tried tethering to my pixel 7a, with T-Mobile as my ISP, with both the USB type c and type a. I am unable to get the router to verify any...
Edward_75
Dec 24, 2024Aspirant
Is there a more detailed manual than the one that came with it? There isn't much to it, like not giving description of use for each port. Not no I don't want to use phone as Wi-Fi hotspot, that is how my last phone overheated.
rcpax
Dec 24, 2024Luminary
if you don't want to do it that way, there is not much that you can do for the hardware that you have. I understand that is not the most ideal way to do that. The netgear mobile hotspot was designed primarily to pull data off of the SIM card. These data offloading methods are sort of secondary "nice to have" abilities that netgear added.
