Edward_75
Dec 22, 2024Aspirant
Tether mr1100 to phone for cellular data
I just bought a nighthawk M1 gigabit LTE Mobile router. I have tried tethering to my pixel 7a, with T-Mobile as my ISP, with both the USB type c and type a. I am unable to get the router to verify any...
Hostever
Dec 25, 2024Aspirant
To tether your Netgear MR1100 to your phone for cellular data
- Connect the MR1100 to your phone via USB.
- Enable USB Tethering in the MR1100 admin settings at 192.168.1.1.
- Turn on USB Tethering in your phone's settings (Android: Settings > Hotspot & Tethering; iPhone: automatic).
For more info, visit Hostever.
- Edward_75Dec 25, 2024AspirantHostever. I have done all this. This issue I believe, but it's not mentioned anywhere is trying to use the data cord provided has one end only for usb-c so that goes into the phone, where the other end is plugged into the type A USB port on the router. None of the information mentions if you have to tether just from usb-c or Ethernet.
- Edward_75Dec 30, 2024AspirantStill didn't work buying a new data cable that match usb-c specs as the router. Pictures show router setting to tether. Phone still greyedhttps://www.amazon.com/dp/B0CRL8TT5P/ref=pe_386300_440135490_TE_simp_item_image out.
