lcesarano
Jul 14, 2020Aspirant
Tethering on a MR1100 SKU 6113B
I was given a Netgear MR1100, the "business" version 6113B. It has been unlocked and its firmware is NTG9X50C_12.06.11.00, GUI is MR1100-100NAS_04.01.80.00 Is there any way to enable internet te...
lcesarano
Aug 05, 2020Aspirant
Hello
Yes, I flashed in it firmware is NTG9X50C_12.06.11.00 (GUI is MR1100-100NAS_04.01.80.00). Do you know whether that is "generic enough"? Even so, no ethernet or even USB tethering working :(
Luca
icaruspony
Aug 05, 2020Luminary
It is the same, software-wise, as the retail ones, then.
The only other possibility could be that this version has removed pieces of hardware. But if that is the case, I don't know why they bothered putting the ethernet port on it. The USB-C port would be needed for charging either way.
Only way to know would be to take it apart and take pictures of the board with the heatsink covers removed for comparison.
- lcesaranoAug 05, 2020Aspirant
Thank you
I do not know whether I feel at ease with taking it apart, but I wil laks a friend and if so publish the photos. A pity that there is no software solution!
