Xop0
Jun 05, 2023Star
THE BEST NETGEAR Nighthawk M6 for Europe and where to buy it.
Greetings. Please tell me the best NETGEAR Nighthawk M6 model for Europe. The most important thing for me is the quality of catching a signal (I will not use a router for a bunch of devices or be far...
schumaku
Aug 12, 2023Guru - Experienced User
The MR6550 is a 5G WiFi 6E Mobile Router (MR6550)
Nighthawk® M6 Pro 5G mmWave WiFi 6E Mobile Hotspot Router, Up to 8Gbps, Unlocked, 5G Sub6(3CC), mmWave(8CC), NR-CA, and NR-DC support, 4G LTE CAT20(5CC), 3G B1/B2/B5/B8
Manufacturer Number for Europe: MR6550-100EUS
The MR6450 is a 5G WiFi 6E Mobile Router (MR6450)
Nighthawk M6 Pro 5G WiFi 6E Mobile Hotspot Router, Unlocked, Up to 4Gbps (same as the MR6550, without the mmWave module!), 5G Sub6(3CC), NR-CA, and NR-DC support, 4G LTE CAT20(5CC), 3G B1/B2/B5/B8
Manufacturer Number for Europe: MR6450-100EUS
MR6500 is a carrier branded Nighthawk® M6 Pro 5G WiFi 6E Mobile Hotspot Router With 5G mmWave and Sub-6 bands for AT&T.
https://www.senetic.bg/ is the official distributor for Bulgaria.
