xMjeed
Feb 13, 2026Initiate
The M7 Pro device is unable to connect to the 5G network with the STC provider 2
My M7 Pro is unable to connect to 5G with STC service provider and only works on 4G in Saudi Arabia. We need a solution to this problem. We have contacted support and they have indicated that the iss...
hkm5007
Feb 13, 2026Tutor
This issue exists across all Netgear versions. The root cause of the problem lies with STC. It is unacceptable that technical support is unable to resolve the 5G blocking affecting Netgear devices
