Vengeant-Duck
Jun 12, 2023Tutor
this app isn't available
MR1100 – Nighthawk M1 Mobile Router, I am getting 'this app isn't available for your device because it was made for an older version of android' when trying to install the app to manage it.
- Jul 31, 2023
Hi, All,
Please be informed that the NETGEAR Mobile App version 7.17.2307.202 is now available in Google Play.
Kindly check if you can now download the App.
Blanca
Community Team
Jun 12, 2023Guru - Experienced User
which app specifically?
And what OS version are you installing it to
I just installed the netgear mobile app on my android 11 and 12 device.
Vengeant-Duck
Jun 13, 2023Tutor
Android version 13, this is what the store on my PC shows. The app won't even appear on my phones store because it is not supported.
