Hugh_B
Jun 29, 2016Follower
Touchscreen security
Hi, Is there a way to password protect (or prevent access) to the touchscreen of the AirCard 790S device ? I have changed the administration login password on the web page configuration for the dev...
alkandery75
Sep 03, 2016Aspirant
Is there anyway to lock the touchscreen, or disable the ability of changing it from the touchscreen... This totally unsecure...
