Danny212
Mar 12, 2020Aspirant
TP Link TL-PA4010
In order to improve video conferencing ability in this Covid19 age, I dusted off a pair of TP-Links that are 4+ years old, connected one of the router's ethernet ports to one, plugged it in, then plu...
Mar 12, 2020Guru - Experienced User
Check the tp-link forum and not the netgear forum if you're using a tp-link device?
do they work in the same room?
Danny212
Oops, my bad, I assumed it was Netgear product because of how something was listed on my network list. Thanks, will look to TP
